Minneapolis Moline Tractors Discussion Forum
403 in UB
ub in ia
09-15-2007 20:30:58
Will a 403 power unit bolt into a UB? thanks
ub in ia
09-16-2007 14:12:52
 Re: 403 in UB in reply to ub in ia, 09-15-2007 20:30:58
will the ub flywheel bolt on to the 403 crank?
MnM44
09-17-2007 18:08:16
 Re: 403 in UB in reply to ub in ia, 09-16-2007 14:12:52
The 403 ring gear will fit on the UB flywheel. That will make the 403 crankcase and starter work in the UB.
MnM44
09-16-2007 10:51:32
Yes it will bolt up the 403 ring gear is bigger and you will need to grind out the inside of the bellhousing to make it fit. You will also need to change the water inlet at the water pump. Or you can take all the internal parts and change them into the UB crankcase.
T.R.K.
09-16-2007 11:58:12
 Re: 403 in UB in reply to MnM44, 09-16-2007 10:51:32
Unless your 403 flywheel is set up for a foot clutch, It is Probably best to build the engine on a 283 crankcase so that you can use the UB flywheel and starter.
Its a bit easier to put a 403 power unit engine into a hand clutch U, Then you only have the starter nose/bell housing interferance to worry about.
There are also water manifold to top radiator outlet and temperature guage sender/hood interferance problems to work out because of the extra tall blocks on a 403.
