Minneapolis Moline Tractors Discussion Forum
Hand clutch bracket
molinebob
09-12-2007 10:29:16
Does any one know where I can pick up the Bracket for the hand clutch, The one I need is the one on the transmission, where the rod from the hand lever attaches to, I thought mine was stuck cause it was solid rust so I grabbed it with a channel lock pliers and it broke, that is after i had it soke in penetrating oil for about a month. I thought maybe the clutch was froze up on it but after the bracket broke I used a pipe wrench on it and the clutch ingages and disengages so I need to find is the bracket. any info would be greatly appreciated. Thanks in advance.
L A Lamb
09-12-2007 12:05:10
 Re: Hand clutch bracket in reply to molinebob, 09-12-2007 10:29:16
Welters Farm supply in Verona, MO. 417-498-6496 Good people L A
molinebob
09-12-2007 10:30:59
The model of tractor is a 1951 UTS.
T.R.K.
09-13-2007 13:13:23
 Re: Hand clutch bracket in reply to molinebob, 09-12-2007 10:30:59
I am thinking that bracket is made as part of the transmission top cover, is that correct?
molinebob
09-14-2007 08:07:56
 Re: Hand clutch bracket in reply to T.R.K., 09-13-2007 13:13:23
No , it comes out the side of the transmission on a splined shaft,on the right hand side beside the battery box, and it has a bolt to tighten it down so it does not slip, unfortunatly mine sat outside for the last 20 years with out being used and it rusted up then broke when I tried to free it up, I am in the process of trying to restore th ething so it will do some odd jobs around the farm when I dont want ot take the big boys out of the shed.
