Minneapolis Moline Tractors Discussion Forum
jet star 3 pto
chuckb
09-11-2007 13:33:48
i have a jet star 3 with a broken pto shaft.i was wondering if if there may be a way to weld something onto the end and make it work or should i just go ahead and replace it.i have the tractor in half rebuilding the engine so my other question is does the tractor have to be in half to replace the pto on a jet star 3
T.R.K.
09-13-2007 06:03:09
 Re: jet star 3 pto in reply to chuckb, 09-11-2007 13:33:48
From reading your post it is unclear which shaft is broken. But since your tractor is already split, now is the time to replace the shaft. I don't know of those shafts are available new (or if you could afford one, if it was.) But you should be able to find a good used shaft.
Try Wendell Everett 740-922-3335, or Welters 417-498-6496.
