Remote to two spool conversion on front loader
Mitch
02-09-2000 09:15:02
I have a M602 with front hydraulic loader that operates off the remotes on the rear of the tractor and controlled with two of the three levers beside the seat. I would like to convert this over to a two spool loader valve controller mounted up towards the right side of steering wheel. Questions
A two spool loader valve is what I need right?
Where do I "tie in" for the pressure and return.
Any drawbacks or advantages of doing this.
Will this leave my remotes free for use with pull implements and will the whole setup work.
Main reason for attempting this is because the "long lever throw" with the current system makes the whole system slow and somewhat bulky to operate.
Sure could use some help from you guys. Thanks
