Minneapolis Moline Tractors Discussion Forum
wrist pin bushings for Z
dlp
09-04-2007 15:26:27
Does anyone know of any other bushings that will interchange with a Z wrist pin bushing? A Minneapolis or some other alternative?
T.R.K.
09-04-2007 19:42:23
 Re: wrist pin bushings for Z in reply to dlp, 09-04-2007 15:26:27
Which Z bushing? There was a change in the early 40's from a brass bushing to a steel backed bushing and they do not interchange. My machine shop was able to press the later steel bushing into the early rods but honing took out all the brass.
I was able to get a set of the early bushings from Welters, 417-498-6496, in 2001 but they said those were the last they had. They may have gotten more, I don't know.
If you want the later bushing, I've gotten a couple sets from Wendell Everett 740-922-3335.
dlp
09-05-2007 04:42:13
 Re: wrist pin bushings for Z in reply to T.R.K., 09-04-2007 19:42:23
This is an engine out of a '40 model. It appears to be a bronze bushing, pretty thin. I had a bearing house look at it & they said they couldn't replace it. I am looking for an alternative part to fix it with.
LW
09-06-2007 06:30:33
 Re: wrist pin bushings for Z in reply to dlp, 09-05-2007 04:42:13
Any machine shop can make a bronze bushing press it in and hone it to size.
T.R.K.
09-05-2007 08:55:39
Have you tried to find some oversize piston pins? They were available in .003 and .005 oversize.
Another thought is if you can get the Z rods honed to the correct O.D. to use the late bushings. Or find a later set of Z rods.
The only other thing I could tell you is that Ford Model A engines use a 1" piston pin. Also there was a certain Buick engine that had a 1" pin. And I am thinking that a certain Allis Chalmers engine used a 1" pin.
I don't know what their pin bushings were like.
