Minneapolis Moline Tractors Discussion Forum
Is a 335 Cat. 1 3 pt????
Clodbuster
09-03-2007 11:57:04
Looking for a beast to pull a finish mower. Is the 335 a Cat 1 or Cat 2? Or both?
The mower is Cat 1 only. Any tractor suggestions?
T.R.K.
09-03-2007 17:46:39
 Re: Is a 335 Cat. 1 3 pt???? in reply to Clodbuster, 09-03-2007 11:57:04
My 335 utility is cat. 1. Actually, the only other MMs that I can think of that are cat. 1 is the BF and BG.
You can pull your finish mower with a larger tractor-say a 445 or jetstar. You will have to adapt their cat.2 hitch to your cat 1 pins on your mower. Sleeves are available that allow you to do this. You may, however have to make your own stabilizer bars if you want to use stabilizer bars with your mower. That is because the cat 1 lower pins are a few inches closer together than they would be on a true cat 2 hitch.
