Minneapolis Moline Tractors Discussion Forum
oil seal for jetstar
Mr Pete
08-30-2007 11:10:47
I need to find a source for an oil seal. It goes on the shaft that the brakes are on. The seal number is CR28699. I punched the old seal out and ruined it, not thinking it would be a problem finding one. I have tried at several bearing suppliers and they have none. Thanks.
pete
mrpete
09-04-2007 20:38:05
 Re: oil seal for jetstar in reply to Mr Pete, 08-30-2007 11:10:47
Thanks men. I bought a pair of National 417344 seals and they fit perfectly at $13 each.
pete
T.R.K.
08-30-2007 17:41:11
Ask your local NAPA to cross reference that CR number to whatever brand they are selling this week. They should be able to get you a seal that will work. It may be narrower than the original.
Or you can call Welters 417-498-6496. They should have new seals. I'm sure I got some from them once.
Some guys double up the seal if its less than 1/2 the thickness of the original. I guess this would work if the outer seal has some grease on the lip. I have never done it myself.
Also, there is an oil drain hole in that plate the seal goes in, it should be open and go downward to drain any ooze through the seal away from the brake disks. (The plate may only go on one way, with the hole down, I don't know.) I have even seen Jetstars with drain holes drilled into the brake housing from the bottom so the oil can drain on out of the case. I did that on one particularly messy brake housing.
Another thing: you need to wrap something around the splines on the shaft to protect the seal when you slide it back up over the splines, so you won't cut the new seal. Other guys do other things,but I haven't had problems using the flat side cut out of a 2 liter plastic bottle wrapped around the shaft.
Kevin Moschenrose
08-31-2007 10:56:42
 Re: oil seal for jetstar in reply to T.R.K., 08-30-2007 17:41:11
Kevlin, I don't know if this is worth anything but I have doubled up seals a couple of different times with no problems doing it.
rvirgil_KS
08-30-2007 13:46:08
I have parts catalog R-2013A for Jet Star and 4 Star.
Brake plate oil seal is original part # 10A7038
I got a pair of seals from our local CarQuest auto parts. They are National 417344
Box flap lists dimensions as: 2.875 x 3.751 x .375
My brother used same seals on his 445
Bob
L A Lamb
08-30-2007 12:09:31
I get my seals (axle and brake ) for my UTU at
DXP in Houston, TX thier ph # is 1-800-825-7233 Hope this helps you L A
