Minneapolis Moline Tractors Discussion Forum
changing gear oil
Mr Pete
08-28-2007 14:57:59
I'm changing the rear end oil in my 1961 jetstar. It's a bit milky in color. Am I correct that there is 10 gallons of oil in there with the amplitorgue?? Also , should I use the common 85-90 weight gear oil? Thanks
pete
mr pete
08-30-2007 11:06:45
 Re: changing gear oil in reply to Mr Pete, 08-28-2007 14:57:59
Thanks
T.R.K.
08-28-2007 18:41:26
I/T manual says 40 quarts, which is 10 gallons.
I would suggest stick with GL-1 lubricant if you can find it in 90wt or 80-90. I read somewhere that GL-5 additives are hard on brass and I know the a/t and the pto use brass clutch yokes.
There are probably machines out there running hi-trans or equivalent without any problems, too.
