Minneapolis Moline Tractors Discussion Forum
445 keeps running when key is turned off
ES
08-27-2007 10:25:52
Just got a 445 when I go to shut it off when it is warm it just keeps running for a couple of seconds then knocks and rotates in other direction. Is this a timing issue or a fuel issue? Also would like to find a seat that goes above the tel-a-flow hydraulics and the power stearing lines that go along the engine. Thanks for the help.
JLM/ Minn.
09-26-2007 16:10:25
 Re: 445 keeps running when key is turned off in reply to ES, 08-27-2007 10:25:52
I would agree with Andy as to things to do--on first glance the "backlash" usually indicates improper timing.. I however always do something else on a REGULAR basis ---before shutting off the tractor--especially after HEAVY loads: I allow it to cool down at a moderate idle --you only need to see the heat gauge needle drop a little, (I like to see it drop more) which prolongs the engines life and helps prevent "dieseling" from overheated plug, carbon or component parts. Good luck!
445 Owner
09-09-2007 14:43:54
Mine does it after I work it hard. After you turn the key off, put it in gear and release the clutch. Kills it immediately; troubleshooting an occasional knock is a waist of time...
G-ROWDY
09-07-2007 18:03:00
It's nice if you have a problem and come to this websight, click a couple pages and you have in black and white. Thank you everyone!
Andy McClure
09-04-2007 03:25:54
Running on or deiseling is usually caused by more than one thing. First, check the point gap,make sure before you check the points that there is not a lot of burning, pitting, or oil on the points. Second, while you are in there, check to make sure there is not a lot of slop or play in the distributor shaft.How to do this, check point break on more than one cylinder, this will genernally tell you if lobes or bearings are worn. Third, check the timing after you have set the points. One-thousanth can make up to 2 degrees difference in timing. When you get this done. You will really be ready to check the timing on the engine. Now it will probably require a carburetor adjustment. Idle and High side. Adjust high side first. Then the idle side.Throttle it up and make high side adjustment. Bring it to an idle and adjust idle side. Now set the idle speed. Next, check the coil wire all the way back to the key and make sure the wire is not bare so that it can't cross fire with another hot wire. Make sure the coil is clean of oil. this can cause cross-over. Make sure the filter, if it has one in the line, is not dirty or plugging up. Low fuel flow usually doesn't cause running on but it helps to know that the fuel flow is good. Make sure the engine isn't to warm before checking this situation. Wouldn't want to drip gas on the exaust system when it is hot. Oh yeah, just for note, after you make the low and high side ajustment. It will probably be a good idea if you throttle the engine up from an idle to see if it is sluggish. This will help make the fine adjustment for the governor. Usually, ajustment of the low side, opening or closing the screw, will fix this problem. One more item on the list, check the choke lever and make sure it isn't to free to open and close when it wants to. You want to be the one controlling the choke lever, not the tractor. May require putting a bend or spring on the cable or arm. Hope this helps, good luck.
guido
09-03-2007 19:03:19
Hey ES
Hi idle will also couse the dieseling effect you discribe.
GUIDO
havvey
08-27-2007 10:59:23
Yes check timing per book #2 check point setting may be to close. #3 check plugs for carbon fowling excessive carbon can cause an engine to diesel but it is rare.
T.R.K.
08-27-2007 18:34:06
 Re: 445 keeps running when key is turned off in reply to havvey, 08-27-2007 10:59:23
No chance the alternator or generator is back feeding the ignition circuit, is there?
Another thing to check is which heads are on it. You didn't say which fuel, but if it is on gasoline using LP heads, it could be dieseling from the extra compression. Does it make a difference if you throttle it all the way down before you kill it?
