Minneapolis Moline Tractors Discussion Forum
tires for my 445
ted regentin`
08-25-2007 06:48:57
Quick question. There is a MM z on e-bay not far from me that no one has bid on. I am not interested in the tractor, but it has new rear tires on it. What is the difference in size from 13.6x38, that I have to what the add says, 124x38. Also, would the rims bolt up?
Thanks,
Ted Regentin
shinnery
08-25-2007 23:11:12
 Re: tires for my 445 in reply to ted regentin`, 08-25-2007 06:48:57
My 445 Repair manual calls for either a 11-38 or 12-38 tire basically depending on weither you have 11 or 12 inch wide rims. In modern sizes, according to a Miller Tire catalog, the 11-38 is now a 12.4-38 and a 12-38 is now a 13.6-38. So you could probably use either size tire on either size rim but they would look right if the 12.4s are on a 11 in. rim and 13.6 on a 12 in. rim. Is the Z a 9 bolt wheel? Both my 445s are 9 bolt non power adjustable. HTH Bryce
