Minneapolis Moline Tractors Discussion Forum
Green MM motor
toolz
08-24-2007 20:40:03
Found a 6 cyl diesel MM motor that"s green- out of an Oliver. How do I find the size, and what it was in? Thanks- Kevin
Clint Youse MO
08-25-2007 09:23:35
 Re: Green MM motor in reply to toolz, 08-24-2007 20:40:03
should be a serial # on the engine with model # that will tell what size it is could be from a couple different tractors either one of the four wheel drives or a G1355 most likely
Kevin Moschenrose
08-25-2007 06:52:01
That engine is most likely from a Oliver 2455 or 2655 four wheel drive. Those are the same as the A4T-1400 & A4T-1600 MM tractors.
