Minneapolis Moline Tractors Discussion Forum
Steel Wheel Removal
molinegb
08-20-2007 07:12:27
Any ideas how to remove rear steel wheel stuck on splined hub for a Z? Can't heat it up with torch. Too big to fit in press.Also have G wheel stuck.
Meanmoline
08-20-2007 20:20:49
 Re: Steel Wheel Removal in reply to molinegb, 08-20-2007 07:12:27
you can use a hydrulic jack and a fair bit of chain you will need to make a fitting for the jack to prevent it from sliping.
Curtis Rink
08-20-2007 09:36:19
A jackhammer works slick. Use the bit with a point. Unfortunately, the jackhammer and air compressor usually have to be rented and you have to take the wheel, axle, and axle housing off the tractor in order to set things so the jackhammer can be used.
