Minneapolis Moline Tractors Discussion Forum
445 park brake
Bruce Mitchell
08-19-2007 14:52:36
Could someone give me an idea how to remove the parking brake shaft from the trans hsg,it dosent seem to be threaded any help will be appreciated.Thanks
Ron Phipps
08-21-2007 17:45:41
 Re: 445 park brake in reply to Bruce Mitchell, 08-19-2007 14:52:36
I just removed the one on my 335 by using a pipe wrench turning out. It wasn't threaded but it came out that way.
Bruce Mitchell
08-22-2007 16:33:40
 Re: 445 park brake in reply to Ron Phipps, 08-21-2007 17:45:41
Thanks for the info Ron,I might just try the pipe wrench.What did you replace it with, just standard rod stock.Thanks again.
T.R.K.
08-20-2007 18:52:57
Could you drill it out? Saw it off flush with the case and drill from there?
Is it bent?
IF you are building a puller, even they need working parking brakes. Tractors with non working parking brakes tend to roll away at very unfortunate times. (I got a blown jetstar3 that rolled into a pond that way.)
Bruce Mitchell
08-21-2007 05:38:07
 Re: 445 park brake in reply to T.R.K., 08-20-2007 18:52:57
Thanks TRK for the idea,the previous owner welded the pawl to make it inop[DUH]so the shaft is patially burned thru and bent,Thanks for you rhelp
