Minneapolis Moline Tractors Discussion Forum
V8 in A Moline
Dieselbear
08-19-2007 13:26:49
Anybody out there ever put a V8 in a U or or any other MM? I was woundering if the rears on any of them could take 7 or 800 hp? and still get into a 6000 lb class.
LW
08-19-2007 19:14:49
 Re: V8 in A Moline in reply to Dieselbear, 08-19-2007 13:26:49
If you were locked in road gear a Z would take it.
dobber
08-19-2007 17:21:02
Years ago had seen someone pulling a MM that had 2 big block Chevys in it. Never saw it break anything on the track.
ken in texas
08-19-2007 15:38:17
Years ago I saw molines with Allison airplane engines for pulling.
Gary from Muleshoe
08-19-2007 14:16:24
I know there is a guy in Abilene, TX that uses U rear-ends in hot rod pullers. He said they hold up better than any he has used. He used big block Chevy engine in his I believe one is a double engine.
shinnery
08-19-2007 22:01:43
 Re: V8 in A Moline in reply to Gary from Muleshoe, 08-19-2007 14:16:24
I have a M602-LP with a stuck engine and a slightly used Chrysler Industrial 440 waterwell pump engine that ran on natural gas and keep thinking they would go well together. Just not sure how hard it would be to make the adapters to bolt them together. Could make it longer and put a torqueflite in there but would loose the PTO drive. Bryce
