Minneapolis Moline Tractors Discussion Forum
RE roller main bearings
dlp
08-18-2007 11:48:55
Is there supposed to be a shield on both sides of the front & rear main bearings? I would think the one on the crankcase side should be removed. Also, what is the front bearing number? Thanks!
Jerry Grant
08-18-2007 22:26:20
 Re: RE roller main bearings in reply to dlp, 08-18-2007 11:48:55
I am just putting my RE engine back toether. Both front and rear main roller bearings have shields on both sides. The front is #RE362 and the rear is RE363. If you need one, I am sure Welters Farm Supply in Verona, MO can help @ 417-498-6496.
dlp
08-19-2007 09:23:24
 Re: RE roller main bearings in reply to Jerry Grant, 08-18-2007 22:26:20
I finally found the number on the bearing, which is a 313ss (double shielded). For $20 I found one on e-bay new. I really don't think the shields are to be left in place. Other engines with this type of mains don't shield them, so that's the way I guess I will go.
