Minneapolis Moline Tractors Discussion Forum
Minneapolis moline G 1000 serial#
dishtech
08-15-2007 16:49:10
I cant find out what year this is by serial #.cant find it in sites.serial 29801145 model 504A-6 G 1000 it is LP tractor,that I have fo sale on this site.but would like to tell what year it is.thanks
Ida Red
11-16-2007 19:32:51
 Re: Minneapolis moline G 1000 serial# in reply to dishtech, 08-15-2007 16:49:10
Have a 1967 G-1000 RowCrop brown belly, with a MM5-16's semi mounted plow.Tractor has a rod out the side of the block.will take $1900. Red
BMG1
08-16-2007 14:13:06
The engine serial number you listed is for a 1966 G1000.
Brian
dishtech
08-16-2007 18:37:31
 Re: Minneapolis moline G 1000 serial# in reply to BMG1, 08-16-2007 14:13:06
Hey thanks alot..that helps alot..I havent gottin back to the tractor to read the Numbers by the cluthc petal. thanks again...Dave
dobber
08-15-2007 17:11:30
The number you want should be on LH side of trans case, 8 digits, starting with a 3.
Ill John
08-15-2007 16:58:42
That's the engine tag
