Minneapolis Moline Tractors Discussion Forum
webster hydraulic pump
Henry. simpson
08-06-2007 15:19:32
I have a Webster Elec hydraulic pump Model 10 A11222
3Xe531R
From a Big Mo 400
It will not sustain pressure. Does anyone know where I could get a replacement. I have gone to several places and no one wants to rebuild it. They claim houusing is worn and not available.
henry simpson
08-28-2007 13:14:34
 Re: webster hydraulic pump in reply to Henry. simpson, 08-06-2007 15:19:32
Thank you all for the replys.
I found a new one on ebay for $35.
Mopower
08-08-2007 07:52:06
(269) 623-5136 BJ Hydraulics Delton, MI
They are experts and can repair anything if it can be done. If not they will advise you on what to look for. They have reworked our MM pumps.
T.R.K.
08-06-2007 18:43:47
I bet your 400 has a 3 point. Does it also have power steering that is powered by the rear pump? That would limit your choice in pumps, you would need one that the priority valve (For the power steering) would attach to.
This may not be a problem. My 400 uses a Vickers pump in the engine side cover for the power steering. (Doesn't have a rear pump or 3 point, though.)
You might want to call Welters 417-498-6496 or Wendell Everett 740-922-3335. They should have some idea what you can do to get up and running.
J Schwiebert
08-06-2007 17:22:19
For what it is worth, gear type replacement hydraulic pumps are sold every day by crossing over the important information from the old pump and then transfering that data to select a replacement pump. Interestesd? may be less money as well too. J.
