Minneapolis Moline Tractors Discussion Forum
MM Distributor Needed
molinemopar
08-05-2007 09:46:50
Looking for a distributor for a 800 HD, Delco Remy part# 1112638-8L20.
dobber
08-06-2007 22:44:05
 Re: MM Distributor Needed in reply to molinemopar, 08-05-2007 09:46:50
I checked the 1112638 Delco and that's a points type distributor that was made to fit MM 504, 605 & 800 not a HEI. There was also a points type Delco 1112594 made fit the 504 used on LPG tractors G704,705,706 & G900 that might work. Otherwise you have to adapt a HEI from 250 or 292 Chevy and there were too many different numbers on those to list them all here. Or adapt a MSD as said too. I have bases yet for Vertex 6 cylinder mags we ran on 605 & 800 but they are straight drive only for irrigation engines with no advance. Those drive bases are going for scrap or will be modified for something else as no one wants them for MM here.
dobber
08-06-2007 08:55:15
Those are hard to find because GM quit making the 292 Chevy motor we made and modified them from. Most you find are all worn out too if were on irrigation units. 250 and 292 Chevy used them so check local salvage yards.
LW
08-06-2007 05:50:04
I make MSD cut downs for those engines out of new distributors.The others are tuff to find.
