Minneapolis Moline Tractors Discussion Forum
UB clutch
j turnbull
08-03-2007 20:55:05
Have a 1953 MM UB,and the new clutch that i installed still slips under load .New clutch disk, pressure plate, and flywheel was machined to 1.406".Had this tractor apart three times now ! Any ideas would help, thanks
fernando mignano
08-06-2007 11:33:20
 Re: UB clutch in reply to j turnbull, 08-03-2007 20:55:05
The clutch problem you deescribe is not enough pressure on the disk. If the pressure plate and the flywheel are in specs, check the free travel on the clutch pedal, also make sure that the motor mounts are tight. I am also assuming that the disk is free of oil.
Hope thie wiil help .... Fernando
Ill John
08-04-2007 18:22:26
Hi Jim, Sounds like that live power clutch could be the problem. Never thought of that. John
jim turnbull
08-05-2007 07:24:17
 Re: UB clutch in reply to Ill John, 08-04-2007 18:22:26
Hi John, good to hear from you.I am going to get this thing going one way or the other.The guys at the pulls have been making fun of me. Talk to you soon, jim
molinegb
08-04-2007 14:39:22
If you have a live pto clutch,take the cover of to see if the clutch plates are saturated in oil. If they are your inner seal between the rearend and pto clutch is gone. They will slip under load,especially a heavy load.
havvey
08-04-2007 10:04:11
yes if you have live power clutch on axel check that too. Could be bad faces on clutch discnot gripping flywheel or Pressure plate.
ubzbpuller
08-04-2007 05:23:39
Have you checked the live power clutch. If your tractor has one on it, that could be your problem not the main clutch. Just a thought.
jim turnbull
08-04-2007 08:28:51
 Re: UB clutch in reply to ubzbpuller, 08-04-2007 05:23:39
Thank you for the reply.Will the live power clutch slipping cause this?.Saw some old forums on this same [problem lastnight, but were too old to send email back.The guy said that he had a problem like this and he did not use the live power clutch , so he drilled three bolt holes through it , and bolted it together. No slip. Sounds kind of extreme, but it workeed i guess.Thanks for the reply, this really has me baffeled. thanks jim t
jim turnbull
08-04-2007 08:21:11
havvey
08-04-2007 04:17:43
Pressure plate not set correct. (wen't through that on a deere 420). Flywheel machined down to much. Rebuilt pressure plate machined down to much. Shaft or gear slipping in transmision etc.
jim turnbull
08-04-2007 08:27:29
 Re: UB clutch in reply to havvey, 08-04-2007 04:17:43
HI , thanks for the reply.My flywheel was machined to the right specs.[ 1.406" ].So i sent the clutch and pressure plate back to the guy that rebuilt it the first time , and he is going to put stronger springs in it.Do not know if there is a shaft or gear that can slip? Tractor drives great , and no noise , loads on the trailer fine and pulls a wagon with no problem, just when you put it on the pulling track. Only goes 100 feet and then slips.and when this happens there is no noise either , just slipping.Thank you again, Jim T
