Minneapolis Moline Tractors Discussion Forum
Need Pushrod source??
MMEd
07-30-2007 20:04:46
changing over from mismatched 4209 and GE30E heads on UTS to 4213 heads - need a set (8) shorter pushrods 16 11/16 vs 17 1/8 for taller heads. Anyone know of a good source - also need 12 5/8 studs or spacers to with shorter heads on a 283 motor.
Big Ernie
08-04-2007 05:36:28
 Re: Need Pushrod source?? in reply to MMEd, 07-30-2007 20:04:46
Everett brother can get any thing you need for a moline
6725 everett valley rd. se
Gnadenhutten Ohio 44629
phone 740-922-3335
fax 740-922-9850
Sorghum head
08-01-2007 09:35:06
You can shorten your own push rods. Just lightly heat the bottom head of the push rod and it will tap right off. Cut the tubing off the correct amount to get the new length including the bottom foot, then reheat the foot and tap it back on. I have shotened many sets, as they are just a press fit. Hope this helps.
savsmm
07-31-2007 03:22:31
my guess is that StaMM Tractors probably has some used ones. Probably a couple other sources as well, such as welters in MO.
http://www.kandrsales.com/sct/index.htm
Greg_Ky
07-30-2007 22:30:15
Give these guy"s a call, they can usually make the push rods in a couple of day"s.
BH Performance P.O. Box 1682 Garden City, MI 48135 Orders (888)-564-0223
Tech (313) 455-1905
