Minneapolis Moline Tractors Discussion Forum
Switching form Ensign to Impco
molinemopar
07-29-2007 13:47:49
Have a 602 propane with an ensign R regulator. Want to switch it to an Impco. On ebay they have an Impco model J for $76, would this work for this tractor, if not which one do I need. Also do I have to change the carb, if so which one would I need? Thanks Alot
Ill John
07-30-2007 04:52:15
 Re: Switching form Ensign to Impco in reply to molinemopar, 07-29-2007 13:47:49
I just put a model J on my M670, used an Impco carb # CA100m-3, works like a charm. Don't have any idea what the #s mean, got this one off a 336 power unit on Ebay. Like to get another for my GTB.
chuckb
07-29-2007 19:49:42
I have a 1964 jet star 3. It has a ensign reg. I just bought a rebuild kit for it but know nothing about rebuilding it. Do you know if i can get one of these Impco reg. for mine?
Thanks
Charles
Shawn W
07-29-2007 15:16:27
Hello
I would think a Model J would work fine, but most everybody would tell you to use a model E.
I got a J on a U with big pistons in it and it works just fine, the only think is it has to get warmed up before it will run on straight liquid under a load, but i always start it on vapor then switch to liquid after it runs for a few minutes.
I would think you might be able to find a used E for about the same money.
I did just rebuild me J and the kit was like $80 and i got a kit for the E and it was about the same money. If buying used and it has laid around any time at all dont be suprised if it needs rebuild.
Good Luck Shawn
Farmall Mann
07-29-2007 15:37:01
 Re: Switching form Ensign to Impco in reply to Shawn W, 07-29-2007 15:16:27
Impco model E is engine coolant heated converter check out this web site www.propanecarbs.com or call 1-877-425-8383 GOOD LUCK BUBBA
Shawn W
07-29-2007 17:29:33
 Re: Switching form Ensign to Impco in reply to Farmall Mann, 07-29-2007 15:37:01
any vaporizer that i ahve seen is used with engine coolant flowing though it. thats why i have to let the tractor warm up before it will run on straight liquid.
The difference in the J and the E is the amount it will flow, the E is plenty big for a 602,which is why when its cold it will change enough liquid to vapor to run a 336 engine with out any problem.
