Minneapolis Moline Tractors Discussion Forum
MM UB Starter
Teebogr81
07-20-2007 13:43:37
Any hints on removing the starter from an MM UB? I have removed the single bolt with a cone nose from the transmission housing. What else is holding the starter in place and how do I get it out of the transmission housing?
teebogr81
08-14-2007 13:19:01
 Re: MM UB Starter in reply to Teebogr81, 07-20-2007 13:43:37
OK,rebuilder couldn't rebuild it. He said the field coils inside the barrel were burned out and he didn't have another one. However, I'm lucky enough to have an M&M collector in my small W. Texas town who has a couple of old starters in his shop. Does anyone know what the resistance across the field coils should be for a 12 volt UB starter?
Thanks,
Tim
garrett1
07-20-2007 15:37:38
After removing the single bolt, place a pry bar between the bell housing and the starter and gently start prying against the starter, using a rocking motion. If there continues to be quite a bit of resistence you can use penetrating spray to help it along.
teebogr81
07-27-2007 10:59:19
 Re: MM UB Starter in reply to garrett1, 07-20-2007 15:37:38
Thanks, it came right out. Now it's at the shop for a rebuild.
