Minneapolis Moline Tractors Discussion Forum
Machining MM Z Head
Todd Brewer
07-20-2007 10:25:19
Does anyone know a way to machine the head on an MM Z? I need to help my machine shop out on how to machine it because it isn't a standard flat head.
Thanks in advance.
Todd
flyrod
07-20-2007 10:52:03
 Re: Machining MM Z Head in reply to Todd Brewer, 07-20-2007 10:25:19
what part of the head are wanting to machine?
Todd Brewer
07-20-2007 10:53:55
 Re: Machining MM Z Head in reply to flyrod, 07-20-2007 10:52:03
I have a head that has some rust pits on the machined surface that mates up with the blocks. I need to machine this surface.
LW
07-20-2007 18:19:37
 Re: Machining MM Z Head in reply to Todd Brewer, 07-20-2007 10:53:55
In a mill is the only way, endmill. It would be a better job if done on a bedmill rather than a knee type mill butI wouldn't worry about pits, and it would be cheaper to buy a head that was good then to surface that one. On ebay a std "Z" head only bring 25-50$ usually. the only heads worth putting much work into are the lp Za heads.
flyrod
07-21-2007 17:27:17
 Re: Machining MM Z Head in reply to LW, 07-20-2007 18:19:37
I agree with LW. You can buy a gas head for a fairly cheap price. But a lp head is the way to go.
