Minneapolis Moline Tractors Discussion Forum
ZA Steering U-joint Cost
MM ZAck
07-19-2007 14:58:12
Ok, after looking through some of the archives for the steering u-joint number (Boston Gear UJNS-16-16), I went to find a steering u-joint today for my ZA. I called up Applied Industrial Technologies, who is a Boston Gear distributor. They could get the u-joint, but it was $231.27. That seems a bit much for that joint. Is there a better source for these u-joints that's more cost effective? Thanks....Zack.
havvey
07-19-2007 17:57:56
 Re: ZA Steering U-joint Cost in reply to MM ZAck, 07-19-2007 14:58:12
try moline salvage yards. yurgo nailed it I have seem this done.
CENTAUR
07-19-2007 17:18:43
Try WWW.globalspec.com/ Try to find APEX brand of u-joints.If you know someone in a that stock the APEX brand you may find they can get you what you need for a fraction of you thought.You can GOOGLE (u-joints APEX) CENTAUR
Yugrotcart
07-19-2007 15:07:06
Zack,
Take some measurements of the U joint that you have. Go to a heavy truck parts store. Bet that you can match it up to a common U joint used on a truck PTO shaft. Around here, heavy truck spring shops also have PTO parts. I'd start there.
Paul
T.R.K.
07-19-2007 18:19:25
 Re: ZA Steering U-joint Cost in reply to Yugrotcart, 07-19-2007 15:07:06
Last time I needed a steering U-joint, (Been 5-7 years, I got 6n series Yokes for 1" dia. shaft and a 6n cross from local John Deere dealer. (Who happened to be cheaper than Tractor Supply by $1 or $2, by the way.) Even cheaper than Tractor Supply. Be sure to measure your shaft. I am pretty sure it is 1", though. (About $55 at the time.)
This was not like the original weld-a-joint. But it looks good and works.
It does seem like I had to drill my own pin hole, but that is no big deal-just put the yoke on the shaft, center punch over the hole in the shaft, drill through shaft and yoke at one time. Then put the pin in.
