Minneapolis Moline Tractors Discussion Forum
Point setting for RTI
DanJ
07-19-2007 10:07:06
I have a 1941 mm RTI and what should the point gap be set at? I have a repair manual but nothing is mentioned about the point gap but only how to set up the timing.
Danj
Yugrotcart
07-20-2007 15:52:57
 Re: Point setting for RTI in reply to DanJ, 07-19-2007 10:07:06
Dan,
Yes, I meant distibutor ignition as opposed to a magneto ignition. Points, condensor, cap are easy to get. Here's some part numbers for you.
These are all"Kem" brand parts.
Rotor # 1270 $6.15
Cap # 1428 $19.82
Condenser # 820 $8.92
Points # TV27HM $22.18
Hope this helps,
Paul
Danj
07-20-2007 18:12:16
 Re: Point setting for RTI/ and another problem in reply to Yugrotcart, 07-20-2007 15:52:57
Thanks Paul, it will be helfull
if I ever need these ignition parts.
Another problem now is the front mount hydrolic pump which is third party along with
the Lull loader and runs off of the front
crankshaft normally where you would place a hand crank.
It is kind of rinky dink with a double t
on a single 1 " shaft going from the motor to the hydroulic pump connecting coupling.
I had the pump rebuilt because of a seal leak but that did'nt work, the seals now is fine but it is leaking around the bolts even
with new gaskets installed and retorking the bolts and it still leaks.
There is no side or rear mount power takeoff
unit, if there was I could addapt a new pump
to one of these units replacing the rinky dink front mounted pump. I may try to addapt a new pump using a new front mount bracket and use two matching couplings,
one mounted on the crank shaft
and the other mounted on the pump shaft getting rid of the rinky dink double t shaft.
The old pump is a 4 bolt bottom mount and
I checked Northern tool but no bottom mounts
available in their cataloge.
Any other suggestions will be welcome
Dan
Yugrotcart
07-19-2007 15:08:44
Dan,
Assuming it's a dist ignition, points would be set at .020.
Paul
DanJ
07-19-2007 21:02:03
 Re: Point setting for RTI in reply to Yugrotcart, 07-19-2007 15:08:44
Paul,
Thanks for your responce but pardon my ignorance, what is a dist ignition?
Is it just short for distributor?
The book says it is a Delco distributor and the points did not look that old but
were badly burnt. They mached up fine with an older chevy small block v8 point set.
I finnally found the engine tune-up area in
my manual and you are right as far as gap
setting the points goes. They say between
.018" -- .024".
Thanks again,
DanJ
