Minneapolis Moline Tractors Discussion Forum
In need of a U cylinder head
Jon Martin
07-16-2007 17:28:59
I am looking for a good cylinder head for a 1949 model U with the 283 A motor. The tractor is set up for gas.... if that makes a difference? My head is leaking water out of the exhaust ports... two small pinholes. Is this a common problem. Perhaps this is why the tractor was parked in 1993.
flyrod
07-18-2007 21:18:46
 Re: In need of a U cylinder head in reply to Jon Martin, 07-16-2007 17:28:59
I have a nice 4210 head ready to bolt on if you are interested?
Jon Martin
07-17-2007 16:30:11
I found a head!!!
Thanks,
Jon Martin
Bill Becker
07-17-2007 11:10:52
I have a GE 30 E head available. It's been pressure checked and is ready to bolt on.
email me if you are interested.
T.R.K.
07-16-2007 19:19:11
Jon, I think you need to know the casting number in order to match the other head. I am thinking it is between the spark plugs and will start with GE or 10A.
I had a GE30E that cracked in the exhaust port. I don't know if it was common or not. Have 2 283s that are not cracked.
Also: There is a 10A cylinder head replacement for most of the GE cylinder heads. It will probably have 18mm plug threads where the GE head probably used a plug with 7/8" threads.
Welters 417-498-6496 (MO), Everett 740-922-3335 (OH). These guys deal by phone. Most times only answer 9-5 in their respective time zones.
