Minneapolis Moline Tractors Discussion Forum
445 oil leak.
T.R.K
07-14-2007 19:14:30
Its the gasket between the blocks and the crankcase on the camshaft side. Has anyone had any success trying to fix the leak from the outside, or is it going to require disassembly and new gaskets?
Gary in Neb.
07-16-2007 06:22:26
 Re: 445 oil leak. in reply to T.R.K, 07-14-2007 19:14:30
mine was leaking there also. had to pull it all the way down to replace the gasket. but soon after that, it was leaking again, and i found that the oil tube that lubes the rocker arms was loose.
G-rowdy
07-16-2007 06:21:54
You might be able to smear something like J.B. Weld on the seam before it is painted or something.
