UTU-?
Dean
01-26-2000 16:38:43
On the side of the engine toward the rear of the oil filter there is a rectangle cover.I assume a pump?goes there and if so why do some cams have one lobe and some have two lobes for what ever bolts on there? thank you Dean
Mike
01-27-2000 09:07:28
 Re: UTU-? in reply to Dean, 01-26-2000 16:38:43
I'm not sure about the double lobes on the cam, but I seen a "G" which uses the same block, that had a fuel pump mounted mounted at that location, and fuel filters mounted on the other side of the block if I remember correctly.
Mike
