Minneapolis Moline Tractors Discussion Forum
grease fitting on water pump on jet star 3
david shields
07-09-2007 16:44:46
grease fitting on water pump on jet star 3 does this grease fitting on water pump water does not ciruclate book shows no themostat
soundguy
07-09-2007 18:39:39
 Re: grease fitting on water pump on jet star 3 in reply to david shields, 07-09-2007 16:44:46
Rats.. my universal translator is not functioning. Let me see what I can glean from your post...
1, You have or are working on a jet star 3
2, there is a grease fitting on the water pump
3, water does not circulate
4, manual shows no thermostat
Ok.. so.. now what.. are you asking a question here? Help us help you...What data are you fishing for?
Soundguy
T.R.K.
07-10-2007 18:57:40
 Re: grease fitting on water pump on jet star 3 in reply to soundguy, 07-09-2007 18:39:39
The jetstar3 water pump is not supposed to have a grease fitting. The bearing is a sealed unit and is not greaseable. That would lead me to think it is either plugging a water hole or else you have some other engine in the tractor. Last senario is your pump was repaired with oddball parts and now it DOES require greasing occasionally.
I think you asked where the thermostat was. It is or was in the upper radiator hose. Try squeezing the hose to find it. It is just a round plug type affair with a thermostat in the center.
