Minneapolis Moline Tractors Discussion Forum
445 jug numbers and sizes
Gary in Neb.
07-03-2007 07:34:04
i was cleaning some old jugs and pistons out of my 445 and noticed that i have two different casting numbers on the two sets of jugs i have, and one set of pistons wont fit in the other. in trying to chase down the differences, i'm not finding much. i dont have the numbers with me, but did different fuels use different piston sizes and jugs?
shinnery
07-06-2007 21:44:53
 Re: 445 jug numbers and sizes in reply to Gary in Neb., 07-03-2007 07:34:04
My 445 Repair Manual gives a p/n of 11A5834B for the cylinders for a gas, tractor fuel or LP Gas engine and p/n 11A9199 for the diesel cylinders. HTH
Bryce
T.R.K.
07-06-2007 05:48:00
Garry, it sounds like one of your jugs has been bored for oversize pistons. Are there any numbers on the top of the larger pistons?
If its a lot of difference in bore-like 1/8 inch your larger jugs may be from a 220 cu. in.
Another way to tell-the 220 jugs I have seen have all had the bottom of the sleeves cast with their cylinder bores joined between them. then a saw slot was made between the 2 cylinder sleeves.
Cast Iron Dave
07-03-2007 19:38:38
How much bigger is the other jug? Someone may have used a jug and pistons out of a 220 cube. I am not up to par on those numbers of jugs. Keep us informed on what you find out.
Gary in Neb.
07-05-2007 05:58:10
 Re: 445 jug numbers and sizes in reply to Cast Iron Dave, 07-03-2007 19:38:38
not much difference, i have not measured, but the jugs from one of them wont fit in the other. one is just a bit smaller. i think one set came off an irrigation engine but the block numbers were the same as mine. just wondered if there were differences between irrigation, gas, propane etc.
