Minneapolis Moline Tractors Discussion Forum
3 pt part
pdonoh
07-01-2007 17:18:01
I don't know what it is called, but the top of the adjustable stabilizer should connect to a small thing that is then connected to what actually goes up and down on my M602. At least that's whats on the left hand side and the right side had two bushings welded together that came apart under quickly under stress. I need to know what it is called and I need to get one. I'm new to MM and don't know any good sources (or part names).
Curt Cooke
07-02-2007 07:35:30
 Re: 3 pt part in reply to pdonoh, 07-01-2007 17:18:01
Left side starting at the bottom and moving up, you have a yoke, into which is threaded a lifting rod, at the top of the lifting rod is a yoke, btween that yoke and the actual 3 pt. lifting arm is a small piece called a trunion. If you have access to a fax, I can provide you with a picture.
CC
