Minneapolis Moline Tractors Discussion Forum
220 Heads
Cast Iron Dave
06-26-2007 20:26:38
I am thinking of fixing up a 445 for pulling. Was just wanting to know if the heads on a 220 engine are the same as on the 445's 206? Is there any other numbers of heads that are high compresion a guy should use. Also should I get 220 blocks to bore out or can you bore the 206's out the same amount? Thanks for your help.
rpllr
06-28-2007 04:24:54
 Re: 220 Heads in reply to Cast Iron Dave, 06-26-2007 20:26:38
I think the heads are about the same. the 5856 heads are used on the lp and they are the highest compression.
