Minneapolis Moline Tractors Discussion Forum
1350 rearend
ollie puller
06-20-2007 16:59:30
I am wondering how much shorter a G 1350 rearend is compared to a G 1355 with the hydra power. If it is significantly shorter I am looking for one in good condition
ollie puller
06-22-2007 18:40:15
 Re: 1350 rearend in reply to ollie puller, 06-20-2007 16:59:30
Thanks,I thought I could make it shorter and get a little more weight transfered to the rearend since I'm having trouble getting it hooked to the ground. What about a g 1000 ?
m kuhns
06-21-2007 17:41:23
A g-1355 rear would be lighter due to the axle housings being significantly smaller. ABout being shorter, the hydra power or an over/under would probably add length unless you weren't to put one in. Our 2-150(G-1355) White and 2155 (G-1350)oliver are about equal in length. I would have to measure to find out, but I bet the 2-150 is longer by a little
glr62
06-20-2007 20:12:02
same
