Minneapolis Moline Tractors Discussion Forum
mmg450 need info please
stanleypavloski
06-14-2007 04:16:28
just bought g450, the 3pt. will not raise up, the hydr. pump works, any sug. on what to look for, also powersterring pump is on machine, but the top whatever goes on pump is missing, the bottom outlet is there, which goes to resivor, comes out of resivor and ends on left side of tractor,also what does pump drive.
Chuck S.
06-14-2007 16:40:12
 Re: mmg450 need info please in reply to stanleypavloski, 06-14-2007 04:16:28
For the 3 pt look under seat should be a thumb screw. Try turning it out, this is made to hold arms up. Gets turned by mistake and locks out 3pt. PS on this tractor consisted of an external cyl, valve unit. This may have failed and was removed. If you want to replace it look for a early Long 445 460 they used same unit. Better yet get stering off later unit complete and change to full hydro/static.
