Minneapolis Moline Tractors Discussion Forum
MM UB - Hydraulic Pump
Tim White
06-12-2007 14:02:25
I have a UB which appears to be leaking hydraulic fluid into the engine crankcase. I assume this is due to some sort of leak in the hydraulic pump on the front of the engine.
Is this correct? Can I rebuild the pump myself? Where can I obtain parts?
yonson
06-13-2007 17:30:13
 Re: MM UB - Hydraulic Pump in reply to Tim White, 06-12-2007 14:02:25
Couple of hints: bearing supply houses will have the bearings & seals, they should not be uncommon sizes & therefore reasonably priced. If you get a seal that is narrower than the original you can locate it where the shaft is not worn, a good DIY project given a little planning.
Alan K
06-13-2007 12:47:40
More than likely the shaft has a grove wore in it from the seal. A new seal might take care of it otherwise you may have to repair the shaft. Im sure new ones are higher that gas prices. ( Arm and a Leg thing ). The Eaton pumps ( rotor )were round and the Websters ( gear )were more square with round edges. The connecting tubes from the pump to the hyd res are different between the two pumps.
brian(MN)
06-13-2007 05:05:07
Seems to me , years ago I had the same problem with my UB. I took the pump to a white/AGCO dealer and he fixed it up right.
Brian(MN)
T.R.K.
06-12-2007 19:07:35
Its probably the seal on the shaft. Being 50+ years old, probably time for bearings too.
Wendell Everett sold me kits for Jetstar pumps a few years ago. 740-922-3335. And he told me how to get the bearings out of the blind holes.
If you can't get up with Wendell, Try Welters 417-498-6496. I'm sure they will have the parts too.
Tim White
06-13-2007 11:35:52
 Re: MM UB - Hydraulic Pump in reply to T.R.K., 06-12-2007 19:07:35
Thanks for all the replies. Welters says they should have a shaft seal, but the UB had two different pumps. Is the difference between the two pumps fairly obvious or are they distinctly marked?
Thanks,
T.R.K.
06-12-2007 19:10:31
Whoops! Forgot that the UB probably had the Eaton pump. (Rotor type pump.) A seal is probably still available, but I bet the bearings and seals will be hard to come by. Still I would suggest you call Wendell or Welters.
