Moline Hydraulic Systems are Weak????
Mitch
01-18-2000 18:30:58
I found a website that lists hydraulic system PSI and GPM's for most MM models and I found them to be higher than most other manufacturers but yet I hear talk that Molines have poor or at least slow hydraulics. How can this be??? Does anyone have a fix for this problem. I have an '63 M602 with specs at 1750 PSI at 13 GPM but yet is real slow with the front loader and the 3 point leaks down.
jackson
01-22-2000 16:26:44
 Re: Moline Hydraulic Systems are Weak???? in reply to Mitch, 01-18-2000 18:30:58
When working right MMs will out lift any other
make of tractor. I will put my 5 star up against
a new tractor of the same size.
galen
01-19-2000 08:58:09
Sounds like your system needs checked out. Ceck your hydralic filter and oil. Could be both or just one need changed. Then you need to check pressure and flow to see if pump is up to specs. As far as rockshaft settling could be stick valves not recentering,worn springs, or bad piston orings. There just several points of wear and adjustment to be checked to make a complete diagnosis aspecially on something with that much age and use.
