Minneapolis Moline Tractors Discussion Forum
1939 MM-RT NEED INFO PLEASE!!!!!!!
Charlotte Harpe
06-06-2007 11:31:34
LOOKING FOR INFORMATION ON THE MINNEAPOLIS MOLINE 1939 RT. MINE HAS STEEL RIMS ON THE BACK AND I CAN FIND NO INFORMATION ON THIS TRACTOR. I AM TRYING TO RESTORE IT. PLEASE HELP
carl grey
06-07-2007 18:31:06
 Re: 1939 MM-RT NEED INFO PLEASE!!!!!!! in reply to Charlotte Harper, 06-06-2007 11:31:34
email me at deerejunkie@aol,com, it has been a while since i have seen my rt, it is at a friends place, i need to go by and look it over
Charlotte Harper
06-07-2007 06:40:08
I posted a pic for you all to see. Thanks so much for all your help.
Link
BMG1
06-07-2007 14:55:11
 Re: 1939 MM-RT NEED INFO PLEASE!!!!!!! in reply to Charlotte Harper, 06-07-2007 06:40:08
It looks like you've got Oliver/HP 70 rear fenders adapted to your R. Rear steel wheels are not listed in any R model parts books which would support the theory of no R models coming from the factory with steel wheels. The R model had a smaller axle than any other MM tractors (Z's, U's, etc) so I'm not sure where those steel wheels came from. They don't look like MM parts. If there are any numbers on the wheel center hub please post them and maybe we can tell you where they came from.
Brian
Charlotte Harper
06-08-2007 06:34:13
 Re: 1939 MM-RT NEED INFO PLEASE!!!!!!! in reply to BMG1, 06-07-2007 14:55:11
Have not found any numbers on the hubs yet, but will be pulling them off today so maybe??? Think you are right about the fenders, believe they were replaced to fit the steel wheels. Thanks so much for your help!!!!! Charlotte
justanothercase
06-06-2007 16:31:27
In my area some farmers put steel wheels on during WW2 since rubber was harder to come by. This is what the old farmers have told me. I have a 39 rt wide front pressed steel rears.. Cant remember what size rubber though. I think this is how they came though. good luck with your project.
Charlotte Harper
06-07-2007 06:38:39
 Re: 1939 MM-RT NEED INFO PLEASE!!!!!!! in reply to justanothercase, 06-06-2007 16:31:27
Thanks for your help. Tractor is dated at the end of the depression so I figure some farmer put steel on the back because rubber was expensive. I posted a pic.
Link
carl grey
06-06-2007 15:53:00
I AM FROM TEXAS AND HAVE A 39 RT THAT I RESTORED A FEW YEARS BACK, THE 39S AND EARLY 40S YEAR MODEL USED A DIFFERENT FUEL TANK THAN THE LATER MODELS, THE SEAT WAS MOUNTED DIFFERENTLY ALSO, I AM LOCATED IN THE DALLAS AREA, WHERE ARE YOU AT??
I HAVE A OF THAT VINTAGE THAT I MIGHT SELL SOME PARTS OFF OR THE WHOLE THING
Charlotte Harper
06-07-2007 06:21:31
 Re: 1939 MM-RT NEED INFO PLEASE!!!!!!! in reply to carl grey, 06-06-2007 15:53:00
I am located in Marshall, TX. About 50 miles from the state line on I-20. How much for the parts tractor? I have a business in Marshall and would have to pick it up on the weekend. Thanks for your help,
Clint Youse MO
06-06-2007 15:50:03
For Parts I use Welters in MO somethings you listed have been on Ebay recently. According to my records the RTU was never produced with factoy steel wheels. MOst of the R models came with out a cab only about 400 cabs produced and about 35000 R model tractors made.
Clint
Curt Cooke
06-06-2007 12:24:06
Your question is quite general in nature. What do you need help with? According to my book, 1939 was the first year for the RT. Parts are generally easily obtained and so are paint and decals. So what do you need?
Charlotte Harper
06-06-2007 13:01:00
 Re: 1939 MM-RT NEED INFO PLEASE!!!!!!! in reply to Curt Cooke, 06-06-2007 12:24:06
I need a radiator, radiator shroud and fuel tank. Not sure where to find parts. I am from Texas and we have seen very few Minneapolis Moline's around here. Would also like to know if the steel rims on the back are original or not. They look original but I have not seen any other RT's with them. Most of the older RT's have a cab on them. We are going back to the farm that we purchased this tractor to see if maybe the cab was taken off. Serial number on this tractor is 401473.
