Minneapolis Moline Tractors Discussion Forum
G950 Lube Pump
Luke Miller
06-05-2007 18:37:51
Does the lube pump above the pto actually pressure lube something or does it just circulate oil between all the compartments? It looks like it just dumps in the Ampli Torc case above everything. Once I replaced the bulb on the indicator on the dash it would flash and flicker all the time. So I took the lube pump off and checked it out. Everything looked ok, I cleaned everything and blew a little air back in the suction line and put it together. The light is off but only has about 15-20 psi with relief turned almost all the way in. Any thoughts on how to get it up to the 30-35 psi it calls for?
Clint Youse MO
06-06-2007 15:52:09
 Re: G950 Lube Pump in reply to Luke Miller, 06-05-2007 18:37:51
If it is like A G900 that is the transmission lube pump. I dont know if it is possible but you might try shimming the pump.
Clint
