Minneapolis Moline Tractors Discussion Forum
1945 MM UT?
Skycarp
06-03-2007 22:50:49
third party image
MM guru's,
I am looking at a MM advertised as a 1945 UT but the serial number doesn't add up to what I see listed for the UT on the YT serial number register. Can anyone here help me with the correct ID of this tractor?
Here are the serial numbers on the ID plate: 557107F.
Also on the ID plate with the serial number is "1 1/4 X 5 4 CYL" and under "Model" it looks like KEF or KFF or KLF
Also cast somewhere on the engine is "UT-100D."
I am attaching a picture of the tractor also.
Thanks
Jim Parisot
06-04-2007 06:45:05
 Re: 1945 MM UT? in reply to Skycarp, 06-03-2007 22:50:49
Skycarp, what you have provided is the serial number off the engine I.D. plate, but it is a relatively late 1945 engine, so the tractor is most likely a 1945. The UT-100D is a casting number off the transmission main case, which you need to be looking at the right hand side of to get the tractor serial number. Hope this helps.
BTW, it is a KEF engine.
Jim
