Minneapolis Moline Tractors Discussion Forum
U302 Super Power Steering
Dale S
05-28-2007 14:12:33
Is the short hose near the power steering pump under pressure?...Its on the return line i think. What type of replacement hose should be used and what are people using for power steering fuild?
Chuck S.
05-29-2007 17:43:32
 Re: U302 Super Power Steering in reply to Dale S, 05-28-2007 14:12:33
The parts book shows two rubber lines. One is 3/8 X 7 in this hose uses clamps to secure it, it is a return line. It will have low pressure in it. The otherline is fitted with connectors is the high pressure line. You should be able to get the return line at auto parts store (fuel line). The other line will need to be made by a hyd line shop. The org. fliud was type A transmission fluid.
