Minneapolis Moline Tractors Discussion Forum
FTA (Transmission Breather?)
Fungus
05-27-2007 13:11:45
Been goofing around with my FTA I recently purchased. There is what looks like a old brass oiler that is piped into the top of the transmission, located just below the gas tank. Is it a breather for the transmission?
Also there are brass valves fitted into the blocks. I assume they are drains for the coolant?
I don"t have a manual for it yet and would just like some confirmation as to what these devices are for. Thanks again.
Tim Wilson
05-28-2007 15:37:49
 Re: FTA (Transmission Breather?) in reply to Fungus, 05-27-2007 13:11:45
Fungus,
The old brass oiler is exactly that, I'm not sure what it exactly oils, but according to the operator's manual there should always be engine oil in it when doing belt work. You assume correctly on the brass valves on the blocks, they are the only way to get all of the coolant out of the blocks. Let me know if you need anything else.
Tim
T.R.K.
05-27-2007 14:06:42
I don't know for sure, but the GT tractors used a chain to sling oil up to the bearing on the clutch shaft. the chain appears to do nothing but go down into the oil and bring some of it back up to the bearing. Perhaps that oiler oils that bearing on your FTA.
