Minneapolis Moline Tractors Discussion Forum
445 ignition wiring
Daniel Dunmore
05-22-2007 12:29:18
Trying to piece together bare-bones wiring. Have "new" rebuilt generator and want to skip ammeter for now. Can I go from regulator "bat" output to starter and from regulator "L" output to ignition switch and then to coil? Thanks for any help. DD
Curt Cooke
05-23-2007 06:15:37
 Re: 445 ignition wiring in reply to Daniel Dunmore, 05-22-2007 12:29:18
I don't see whay not. The risk you run is if the regulator cut-out fails for some reason, you won't know about it until the generator is ruined or your wires start on fire.
karl f
05-23-2007 19:36:36
 Re: 445 ignition wiring in reply to Curt Cooke, 05-23-2007 06:15:37
add a fuse that barely exceeds the rating of the gen output and that should cure any overloading concerns.
karl f
T.R.K.
05-23-2007 19:00:16
The only exception to what you describe and what was on the tractor originally is the ammeter is wired between the 'bat' on the regulator and the hot connection on the starter.
The 'L' was always wired to the ignition switch and lights. 'L" stands for 'Load'.
If you have the original ammeter still on the tractor, and it has continuity between the posts, I would wire it in, it may still work. I know its one of those special gauges that mount in that cluster.
Just 2-3 months ago I did the same thing to a 445 universal that I bought.
