Minneapolis Moline Tractors Discussion Forum
piston diameter for U
Roger H MI
05-19-2007 15:18:50
Had a valve drop through a piston on my U. The diameter of the piston measure's 4.365" stamped with "std" on top of the piston. Can anyone tell me what kind of piston I have and where I can get a replacement for the one I have? The piston is aluminum.
MnM44
05-22-2007 06:47:50
 Re: piston diameter for U in reply to Roger H MI, 05-19-2007 15:18:50
You can put the 4.625 bore blocks on pretty reasonably probally cheaper than buying new pistons for the small bore you have now.
Jerry Cent. Mi.
05-23-2007 15:33:34
 Re: piston diameter for U in reply to MnM44, 05-22-2007 06:47:50
4.625 bore blocks are typically 403 blocks that require 6 inch stroke verses the 5 inch stroke in the U. In a U with a 4.625 bore a G crank and some machine work to fit it in a U would be tequired also.
Roger H MI
05-24-2007 17:13:26
 Re: piston diameter for U in reply to Jerry Cent. Mi., 05-23-2007 15:33:34
Can I use the 403 blocks and pistons with a U crank?
Say What
05-24-2007 12:00:05
There is no maching work required to put G blocks and crank in a U
Roger H MI
05-22-2007 14:23:23
Boy I don't know if you could go 4 5/8 with original blocks. I still use this tractor to pull a three bottom plow.
MnM44
05-23-2007 08:27:40
 Re: piston diameter for U in reply to Roger H MI, 05-22-2007 14:23:23
You cant go 4.625 in the original blocks. What i said was you can get a set of 4.625 blocks and pistons used about as cheap as buying a new set of pistons and rings.
Roger H MI
05-23-2007 10:28:56
 Re: piston diameter for U in reply to MnM44, 05-23-2007 08:27:40
That would give the old girl "some get up and go".
What would be involved in doing this. Would everything from an M5 bolt right up? What do you think the cost would be? I have checked with Welters on a new piston, haven't heard back from them yet but they thought they had one. just had to locate it. How about sleeves?
MnM44
05-24-2007 11:56:48
 Re: piston diameter for U in reply to Roger H MI, 05-23-2007 10:28:56
A good used set of blocks and pistons for an M5 run about 350.00. A new set of ring will cost about 100.00. You can bolt the blocks right on the pistons are a little too tall. You can either run a couple extra block gaskets or turn about .160 off the top of the pistons. The 403 blocks have nothing to do with what we are talking about. All the M5 602 670 G1000 vistal 1350 1355 and A4t lps or gas all used the 4.625 bore blocks unless they had the Hd800 in them of course
ken in texas
05-21-2007 17:26:06
YEARS ago when we farmed with UT,s I had one bored 125 thousands oversize( second boreing) and used pistons supplied by machine shop and did not have cylinder problems,but you never can tell.Dont know piston brand....
MnM44
05-19-2007 18:42:03
Sounds like you have an M&W overbore piston. Std bore on a U is 4.25 and the M&W company made an 1/8 inch overbore piston and marked them Std. I would try welters in MO 417 498 6496
Roger H MI
05-20-2007 13:46:39
 Re: piston diameter for U in reply to MnM44, 05-19-2007 18:42:03
You're right it is an M&W piston. A1 122 made by M&W. Are they still in business? and what is the story behind M&W products? I don't know if you could bore any larger diameter and be safe. I guess I have too many questions and not enough answers.
Tom Peterson
05-21-2007 22:35:24
 Re: piston diameter for U in reply to Roger H MI, 05-20-2007 13:46:39
Welters sell Jahns pistons that are 4.375 +.060" over for the U engine.
