Minneapolis Moline Tractors Discussion Forum
U carbs
Shawn W
05-15-2007 18:09:33
Hello
looking for some info. I got a 39 UTU with a ttx 36 mavel schebler carb. its been years since its been touched and i need a gasket set and a float valve and seat for it. everbody i asked said i would have to make my own gasket, but i really hate that job. andbody got a supplier for kits or parts for these old carbs. tractor is original and does run so i aint changing to the newer carb.
thanks
Shawn
Shawn W.
05-17-2007 10:50:53
 Re: U carbs in reply to Shawn W, 05-15-2007 18:09:33
Hello everybody
Thanks for all the good help. so there is no kit for the TTX-36 right?
I havent emailed or called Matt Gall yet, but do you think he would have the pieces i need?
I have a newer carb off my 1952 U, but the load jet has been drilled huge, for Ethanol. dont think it will work with out a new jet.
However my old TTX-36 that is on my 39 U runs it just leaks gas everywhere and has sit so much that its all varnished up and just needs a good cleaning. Thats why i dont want to change my carb.
Thanks Everybody
Glen in TX
05-16-2007 19:52:08
The TSX-36 uses the popular TSX kit K7505 Zenith-Marvel Schebler number that cost about $22 with gaskets, needle seat kit, and air needle and spring. Float and other parts are separate or have to buy a complete overhaul kit. Any tractor supply place or NAPA should be able to supply the basic kit. K7505 and K7510 kits fit the majority of all TSX carbs made.
Oops!! wrong carb.
05-17-2007 03:51:14
 Re: U carbs in reply to Glen in TX, 05-16-2007 19:52:08
He has a TTX not a TSX. NAPA will not have a kit for your carb. Good luck trying to find one.
Glen in TX
05-17-2007 09:17:39
 Re: U carbs in reply to Oops!! wrong carb., 05-17-2007 03:51:14
Well.... I looked for that but even the later Marvel Schebler catalog doesn't even list a TTX. Yeah the TSX-36 does fit a MM but the later RT tractors so too small. For hard to find kits try thecarburetorshop.com Zenith-Marvel Schebler can still sometimes supply parts for those older carbs too but it takes a while at times for a dealer or warehouse to order them in from factory because Zenith won't sell to you direct. Also try V.E. Petersen, Toledo Ohio, 1-800-537-6212
Yeah I messed up Mr. OOPS but why didn't you give him the replacement numbers for a U? Marvel Schebler TSX-67 or Zenith 14999 up to 1955 Us and 1955 and later used MS TSX-624 or Zenith 14999. Yes, the Zenith 14999 new carb is a universal replacement type.
Mr OOPS!
05-17-2007 09:28:29
 Re: U carbs in reply to Glen in TX, 05-17-2007 09:17:39
I didn't waste my time with all the BS you said because he didn't want a new carb. Can you read?
Glen in TX
05-17-2007 12:09:44
 Re: U carbs in reply to Mr OOPS! , 05-17-2007 09:28:29
Maybe you should sell him a kit Mr. Perfect :P Good luck finding one because you couldn't find it.
Ill John
05-16-2007 05:37:11
2 ways to fix this: send it to Motec Engineering in Indiana-$75.00 complete rebuild or NAPA-Echlin kit # 2-1404
Shawn W
05-16-2007 16:49:07
 Re: U carbs in reply to Ill John, 05-16-2007 05:37:11
thanks.
i have had Matt do lots of work in the past, i just really dont wanna send this carb out. im suprised napa has a kit, but i think ill go that route thanks again
Shawn
