Minneapolis Moline Tractors Discussion Forum
zenith sediment bowl anyone?
karl f
05-05-2007 23:41:38
my U has a zenith sediment bowl assembly. years ago the glass jar unthreaded and hit the pavement and shattered. has anyone come up with a better replacement than opaque plastic medicine bottles? i'd like to find something in clear or transparent glass. i cannot believe how tiny it is!
hard to replace it with a more common style because of the small space and small diameter required. unless a bigger assembly would have an offset nipple for clearance
karl f
05-09-2007 13:36:20
 Re: zenith sediment bowl anyone? in reply to karl f, 05-05-2007 23:41:38
i found the cast part is junk, so i'm gonna replace it with something. one of our parts Us had a full size one like a farmall on it, so i'll try a new one like that, since function is more important than correct part right now. karl f
MM PA
05-09-2007 06:29:14
You can get them from McMaster-Carr for a couple of dollars.
Ill John
05-08-2007 14:55:57
Motec is the place to get that bowl, I've paid $16.00 each which is roughly 5 times what Motec charges.
Sand
05-07-2007 20:55:39
I got mine through my local Agco dealer.
JLM
05-07-2007 08:18:03
My Z has the tiny threaded clear glass bowl about one inch in diameter and two inches length. I have a Hayward swimming pool sand filter with a sight glass on it that is an exact replacement. You might check with a swimming pool supply store.
Check part number 17 in this link.
Link
newtothisgame
05-06-2007 19:13:15
ebay is a good place to look and rarly you can find mini honey or mustard jars that are close and work
BMG1
05-06-2007 10:43:18
Karl,
Motec Engineering in Tipton IN has them. 765-963-6628
You can also get them off of eBay at times.
Glen in TX
05-06-2007 08:32:13
Bowl is threaded? If you need small check small engine supply places for very small sediment bowl. Ask for one for older Briggs and Strattons.
ted regentin`
05-06-2007 07:42:40
I dropped the sediment bowl for my 445, and the local Napa store had one in stock. I don't know what yours looks like but it is worth a try.
Ted Regentin
