Minneapolis Moline Tractors Discussion Forum
new(er) and replacement manifolds
karl f
05-04-2007 20:23:26
the U(tu) operators manual talks about the heat adjustment on the exhaust manifold outlet. where should that be set in today's gasoline formula? also are the new aftermarket replacement manifolds adjustable that way or are they fixed in a position? and which position?
thanks karl f
Glen in TX
05-05-2007 12:05:04
 Re: new(er) and replacement manifolds in reply to karl f, 05-04-2007 20:23:26
The warm or hot position was for running older fuels like distillate or kerosene. The colder position is for gasoline. It took more heat to get distillate fuels and kerosene to vaporize and combust without pinging or pre-ignition knock. I think the fuel valve is available new reproduction for U manifold also. That's why the pulling guys are going with manifolds off later MM gasoline tractors and different carbs that were designed for gasoline from the start.
karl f
05-05-2007 21:35:21
 Re: new(er) and replacement manifolds in reply to Glen in TX, 05-05-2007 12:05:04
doesn't seem that adjustable though, being you have to loosen a few bolts and turn the outlet.
this tractor is/was gas only.
-karl f
