Minneapolis Moline Tractors Discussion Forum
HYDROLIC FLUID
m5
04-26-2007 19:55:48
GOT A 1960 M5 THAT I CANT FIGURE OUT WHERE TO FILL HYDROLIC FLUID. THIS TRACTOR HAS A 3 POINT. HAVE A PARTS TRACTOR WITHOUT 3 POINT AND IT HAS A CAP WITH A DIPSTICK UNDER THE SEAT BUT I CANT FIND IT ON THE ONE WITH 3 POINT. WHAT FLUID SHOULD I USE? HAVE A BARREL OF HYTRAN FOR MY IH's WILL THIS WORK? THANKS!!!
herald
04-27-2007 20:07:58
 Re: HYDROLIC FLUID in reply to m5, 04-26-2007 19:55:48
M5, I made my own fill tube. On the right rear corner of the reservoir I took out the 1/2 pipe plug and put a short nipple with a "T" pipe fitting, put the original plug in the botton hole, a 6inch nipple on the top, drilled a 1/4 inch hole in a female pipe plug cut the head off a spike, welded it in the hole of the cap, filled the reservor to within an inch of the top, in the place under the seat, stuck my homemade dipsick in the 6 inch nipple saw where the oil level was, made a mark on the spike with hacksaw, painted it and looks factory. Now can add, drain, and check hyd oil with ease.
schrocky
04-27-2007 05:14:18
Your fluid will work. Now the fluid fill is kind of dumb ...but you can fix that also. There is a set of lift controls under your seat that is held on by 4 bolts. Take it off and fill to about 1 inch from top. There should also be an upturned 90 in front of that with a pipe plug, and that is also a level plug. Now if you get real lucky and find a late model 602 or early 670 you will see they have a fill tube and dip stick in the back right of the system.You can duplicate this very easily if you have a pattern. I know a guy who makes them for $70 but I found one for $5 at bone yard
