Minneapolis Moline Tractors Discussion Forum
lp fittings
rpllr
04-22-2007 20:01:41
Does anyone know a source to buy some lp fitting to go from the hose to the valves on an lp tractor. I have one set up now, but I would like to do a second tank, but can't find the screw on adapter to fit the fill valve on the tractor tank. I could also use some more bleeders to screw on the vapor return side. Any help is appreciated.
L.K.MACK
04-23-2007 21:13:20
 Re: lp fittings in reply to rpllr, 04-22-2007 20:01:41
A LOCAL FARM COMMUNITY LP DEALER SHOULD BE ABLE TO HELP YOU WITH THIS JUST TELL THEM WHAT YOU WANT TO DO.
IF YOU ARE WANTING MORE BLEEDERS SO THAT YOU CAN FILL FROM YOUR OWN TANK? THERE IS A SPECIAL PIECE THAT YOU CAN SCREW INTO THE RETURN SIDE OF YOUR TRACTOR TANK THAT WILL RELEASE PRESSURE QUICKLY AND ALLOW YOU TO FILL IN JUST MINUTES.
YOU MUST HAVE A WET LEG IN YOUR OWN SUPPLY TANK TO FILL FROM THAT TANK.
VAPOR MEANS EXPLOSION! I LIKE TO FILL WHEN IT IS BREEZY ENGINE OFF!! NO SMOKING!! NO SPARKING CONTACTS!! RUNNING MOTORS!! NOTHIN!!!!! !!!!! !!
Clint Youse MO
04-23-2007 07:01:55
Try your local LP gas supplier mine usually has that stuff on his truck
Clint
