Minneapolis Moline Tractors Discussion Forum
MM Head
Head ID
04-22-2007 19:14:24
A friend called asking if I could ID a MM head for him. It is for either a MM R or Z motor and the last 3 digits are 083 (that is all he could remember). I can not match those numbers with any heads in my books can anyone tell me what this head is and it's compression ratio?
Thanks!
MMEd
04-30-2007 19:04:45
 Re: MM Head in reply to Head ID, 04-22-2007 19:14:24
Z or R heads will have a casting number on right side as I recall - it will be RE226C, RE226D, or RE226E - or later tractors 10A2647 or 10A2648. Heads were used on both motors but at different CR - find displacement - easiest is on tag riveted to side of block - and casting number above and I can probably get you CR at least as it left factory.
