Minneapolis Moline Tractors Discussion Forum
m5 pto stuck
m5
04-22-2007 18:47:17
JUST BOUGHT M5, NEW TO MM. PTO LEVER DOESNT MOVE SEEMS TO BE IN REAR POSION BUT THE PTO DOESNT SHUT OFF. FORWARD ON REARWARD OFF?
ed dornbush
04-24-2007 05:53:05
 Re: m5 pto stuck in reply to m5, 04-22-2007 18:47:17
MINE DOES THAT ,ALL I DO IS STEP ON BRAKES AND IT STOPS DON'T NO Y
schrocky
04-23-2007 02:55:15
Fwd is on back is off. They will creap because of no pto brake. If it does not stop under load then yes something has went amiss and you need to open it up
Kevin Moschenrose
04-22-2007 20:41:06
I just got mine unstuck on my jetstar. I had to remove the three point rock shaft and the rear end housing cover to get to mine. I found that it was stuck due to be stored for some time and moisture in the rear end had flashed keeping it stuck over center. These are pretty muck the same on the two tractors.
schrocky
04-23-2007 02:52:13
 Re: m5 pto stuck in reply to Kevin Moschenrose, 04-22-2007 20:41:06
Fwd is on back is off. They will creap because of no PTO brake but if they do not stop under load yes open it up something has went amiss
